It is currently Thu Oct 19, 2017 12:25 pm
 Post subject: Reliability of measuring tools?
PostPosted: Thu Jun 21, 2012 3:39 pm
I got a big aluminum square from Menard's or Home Depot (forget which), and while I was working on drawing panel cut lines onto my plywood, I realized that so and so many inches on that thing does not match that measurement on my old steel square and several other rulers.
I had a bit of erasing to do becasue of the inconsistency.
If you can't trust a ruler, well, I don't know,
Anybody else experienced such?
Or, Maybe the square that seems off is actually a state of the art instrument, adjusted for the curvature of the earth?
 Post subject: Re: Reliability of measuring tools?
PostPosted: Thu Jun 21, 2012 5:47 pm
An old timer taught me the first thing you did with a new framing
was to square it, he did the squaring with a center punch .
not sure about the markings maybe its in tenths or mm
PostPosted: Sun Jul 01, 2012 9:34 pm
Had that problem before. I have came to the conclusion that nothing is square.
PostPosted: Mon Jul 02, 2012 6:11 am
I was taught to always check a new square by putting against a straight edge, mark along the edge, then flop it side to side, and check your mark. Most of them will not be perfect, but can be adjusted with a punch to be the same. A level should also be checked, but sometomes you just have to go with It looks right.
Users browsing this forum: Yahoo [Bot] and 2 guests
