New Laker
Martin in Fonthill
New Laker
Post by Martin in Fonthill » Sat May 15, 2010 5:26 pm
I am finally getting started, now the weather is too cold for the epoxy to set up.
Martin
Re: New Laker
Post by OnkaBob » Sun May 16, 2010 5:30 pm
That hull looks really good - going to be a specially good Laker when she's finished.
I notice that the internal frames are "non standard" - does this mean you're going for a custom deck design?
Re: New Laker
Post by jem » Sun May 16, 2010 5:34 pm
The one does look rounded.
Martin in Fonthill
Re: New Laker
Post by Martin in Fonthill » Mon May 17, 2010 9:35 am
I want to strip the deck in one piece and the boss wants to keep the front peaked but the back rounded.
I am still figuring out how to set my forms.
Martin in Fonthill
Re: New Laker
Post by Martin in Fonthill » Fri Aug 13, 2010 9:37 pm
Finally had some time to work on the kayak, starting the deckImage
Re: New Laker
Post by craiggamesh » Sat Aug 14, 2010 1:40 pm
Looks really nice! looks like you added a few forms.
Phishtech
Type of boat I like: Laker Okwata TV 15-29
Re: New Laker
Post by Phishtech » Sat Aug 14, 2010 3:03 pm
How about some specs, please, on the length, wood used, where you live, etc.
Phishtech
Martin in Fonthill
Re: New Laker
Post by Martin in Fonthill » Mon Aug 16, 2010 5:27 pm
It is the 13' Laker, instead of plywood I glued up the body panel from strips, I started with spruce for the bottom then changed to cedar for the side panels. this was the first time i have ever done this ,the panels turned out fairly rough, after I started sanding to smooth them I gave up and simple fed them through the planer, they came out nice but ended fairly thin 3/16". I stitched and glued them as per plans and put 6 oz fiberglass on both sides. I took the bulkheads and rounded the top and glued them in. I then used the lines from them to the bow and stern and created temporary forms which are then hot glued in from the shear clamp. I also made some temp. frames out of waste strips which sits on the kayak bottom to support the temp form.
I used cedar which I picked up at home depot, for the last 6 month ,every time I went there I rooted through their cedar lumber to find some good boards.
The 10' premium 4x4 posts yielded some nice lumber.
I live about 20 minutes from niagara falls, but this summer spent most of my time in the wasaga - midland area
Martin
Last edited by Martin in Fonthill on Wed Aug 18, 2010 10:36 pm, edited 1 time in total.
Martin in Fonthill
Re: New Laker
Post by Martin in Fonthill » Wed Aug 18, 2010 9:10 pm
Got a little more done today. Image
Re: New Laker
Post by jem » Wed Aug 18, 2010 9:21 pm
very nice!!!
