Finally moving on to the epoxying stages of the boat. Raka sent my goo to my old address and it took about 2 weeks to get. Honest mistake.
I was wondering if any of you all have tried this. I mixed up my thickened epoxy for tacking everything together, then put it in a ziploc bag, cut the corner off, then filled the gap squeezing it like a pastry bag. I did it both ways and found the patry bag method to be quicker and easier. Plus I felt like I was filling the gap more consistantly. Then I went back and only had minor touch up with the putty knife. I did find that the thinner bags can burst.
Anyway, it seemed to work for me.
Moving on....
tack welding
I have taken to using empty caulking type tubes. You can buy them for about a $1.50 ea. The work excellent but there is a little wast left in the "nozzle" but you can push that out with a dowel.
http://i111.photobucket.com/albums/n122 ... es_200.jpg
I've gotten to the point where I just use a wooden craft stick to apply filleting material.
First, I mask off each seam like shown above.
Then, I apply the filleting material or tack weld and smooth it out with a gloved finger. If a tack weld, then I just smoosh into the seam.
Next, I pull the tape up (you do this right after the material is applied. Don't let it cure before removing the tape!)
Finally, after you pull the tape, you'll have just a small "step" in the fillet. I gently drag a glooved finger over it again to flatten that step. Seam come out looking very clean.
The bag and tubes also work good. It's just a matter of what makes the process easiest and enjoyable for you.
