Eno
banoe
Eno
Post by banoe »
Hi Matt,
I am looking for a light weight solo canoe. Has any one built an Eno? Could I build one out of 4mm plywood and what would it save in weight? Or could I use 3mm for sides and 4mm for bottom with cloth inside and out?
I've sold several copies but no one has sent pictures.
You could built in the manner you suggested but may need some selected reenforcement in the seating area.
You could probably knock the weight down to around 35 pounds.
zeb
Post by zeb »
Hi banoe
Im building an Eno,ive cut it out but havent stuck anything together yet.
hoping to get some work(play) done on it over the next few days as im having the weekend off from the grindstone :D
I will post some piccies when I make a little progress
cheers zeb
banoe
Post by banoe »
Zeb,
Can't wait to see the pictures
Matt,
Like Old Sparkey did in his Swamp Girl floor? Do you think I could get it under 35lb?
banoe wrote:Zeb,
Matt,
yep and yep
