Bead & Cove joints?
Frog
Type of boat I like: Trapper 18-36 Canoe
Bead & Cove joints?
Post by Frog » Thu Sep 22, 2011 7:04 pm
Hello,
Before I order a Trapper plan set, was wondering if anyone on the forum
has used Bead & Cove joints on these plans?
Thanks
Re: Bead & Cove joints?
Post by jem » Thu Sep 22, 2011 8:01 pm
You mean building it as a wood strip hull in the traditional manner or make the plywood flat panels out of strips of wood?
Guest
Post by Guest » Thu Sep 22, 2011 10:30 pm
thanks for the response Matt ...
I was thinking about using a bit & cove on all the joints,
helping with fit up and the butt joints ...
goanywhere
Post by goanywhere » Thu Sep 22, 2011 11:09 pm
I think he's referring to the method of strip building where the strips are made concave and convex alternately on each edge so that they fit together more smoothly. I think I've read about this on this forum.
Frog
Post by Frog » Thu Sep 22, 2011 11:30 pm
Yup, was thinking of beading & coving the ply edges of the parts
before the fit-up and tie
Post by jem » Fri Sep 23, 2011 6:30 am
oh. Interesting idea.
But keep in mind with stitch and glue building, precise joints are not required.
goanywhere
Post by goanywhere » Fri Sep 23, 2011 8:48 am
Frog wrote:Yup, was thinking of beading & coving the ply edges of the parts
Bead and Cove is only used in constructions where the sections contact each other directly (such as stip plank building). In stitch and glue construction the sections don't meet, in fact it is important that they don't (viewtopic.php?f=7&t=33), so bead and cove is pointless. :)
Post by jem » Fri Sep 23, 2011 9:25 am
On power boats or large sail boats, hard spots (wood on wood contact) are not a good idea. Not an issue on paddle craft. The spacer idea helps tame unrulely plywood. But it is an option, not requirement.
Frog
Post by Frog » Fri Sep 23, 2011 9:32 am
there are plenty of strip built canoe and kayaks out there, why not mix the 2 techniques?
makenmend
Post by makenmend » Fri Sep 23, 2011 9:53 am
frog, good to "think outside the box" but with stich & glue your talking hard chines (angles) so bead and cove application would be difficult to say the least.
MM
