Dynel cloth or graphite?
puddy
Type of boat I like: Canoe or kayak
Post by puddy » Sun Dec 04, 2011 5:05 pm
I'm at the point now that I need to order my fiberglass. I plan to glass inside and out instead of taping.
I was on Duckworks site and they have dynel cloth to improve abrasion resistance. Any one have any experience with this?
I'm building the touring pirogue T that will mostly be used in a river that has a lot of shallow rocky sections, potentially going over a lot of logs and rocks and being pulled up onto rocky shores.
I was planning on graphite, though I don't really like the look of it. Does any one know does dynel wet out clear? How does it compare to graphite for abrasion resistance?
Thanks a lot,
Chris
Re: Dynel cloth or graphite?
Post by jem » Sun Dec 04, 2011 5:42 pm
It work much like e-glass ("normal" fiberglass). But it swells as it absorbs resin. It's preferred to be used with vacuum bagging.
You can lay it up by hand but be aware of the swelling issue. As a wear strip, shouldn't matter but do a test piece first.
puddy
Post by puddy » Sun Dec 04, 2011 6:34 pm
Thanks for the reply. Do you know how it compares to graphite for abrasion resistance?
Thanks,
Chris
Post by tx river rat » Sun Dec 04, 2011 8:14 pm
Everyone I have talked to says they will never use it again.
Post by jem » Sun Dec 04, 2011 9:00 pm
The graphite helps make the surface more slippery and deflects the things that dig into the hull. I don't know which is more abrasion resistant.
For the trouble, you might be better off just doubling up on strips of e-glass or add some wood runners.
puddy
Post by puddy » Mon Dec 05, 2011 5:07 am
tx river rat wrote:Everyone I have talked to says they will never use it again.
that's good to know
goanywhere
Post by goanywhere » Thu Dec 08, 2011 6:28 pm
puddy wrote:Thanks for the reply. Do you know how it compares to graphite for abrasion resistance?
Thanks,
Chris
I coated the bottom of my yak with epoxy/graphite. At first I wasn't sure if it was any more scratch resistant than ordinary epoxy, but after a couple of weeks I am now convinced. It does seem to take a bit longer to cure to maximum hardness than straight epoxy, but once hardened it is fantastic.
LesForgue
Post by LesForgue » Wed Feb 08, 2012 4:05 pm
That guy at http://tomangelakis.tripod.com/graphite_bottom.htm (cited in a graphite thread in the Tips and Tricks section,)
he mentions an ongoing nuisance of the graphite rubbing off on hands, clothing, etc,
anyone have a remedy for that?
Thanks.
Post by Mick » Wed Feb 08, 2012 7:02 pm
G'day les,
I think that bloke is talking through his bum. Either that, or he might have put waaaaay too much graphite in his epoxy. I use about 20% by volume of graphite to the mixed resin and have never had any problem with the black stuff rubbing off on me. it sets as hard as a rock.
The bottoms of my boats get an awfull flogging on rocks, gravel, logs and the like, even barnicles and oysters at times and the graphite mix works a treat for me.
:D
and the worst is a few scratches on the bottom :D
that another layer of graphite easily fixes. :mrgreen:
john the pom
Post by john the pom » Wed Feb 08, 2012 7:22 pm
Reckon this would be an issue only if the graphite/resin surface was sanded. Why sand back a protective layer? Never had it happen to me.
Cheers John.
