Page 1 of 1
[ 9 posts ] |
| Author |
Message |
JGood
Post subject: stripped Freedom 15 as a SOT? Posted: Sun Apr 15, 2012 10:52 am |
Hi Matt Through some delays, I am finally finishing my Sabalo 15. After 40 years f using power tools with no accidents, I let a trim router kick back and run a 1/2" top bearing pattern bit up my left thumb. It hit just above my thumb nail and went all the way up above the top knuckle leaving a 1/2 inch of hamburger in its wake. Fortunately the tendons were only knicked and after 3 hours the surgeon was able to stitch it back together. It is completely healed now and looks remarkably better than I would have believed. My father always told me " If ya know better, do better and things will work better" I knew better and it didn't turn out well. Next, I want to either do another Sabalo 15 as an ss&g or put a SOT cockpit in a Stripped Freedom 15. I have studied the hull shapes and I think the Freedom may actually have more flat hull in the water than the Sabalo. What do you think? I believe a stripped SOT would get alot of attention in my area. I have not decided if I would want a tank well or not. Maybe a tank well option would be a good idea. I would appreciate the opinions of Matt and any Freedom15 owners. Thanks Jesse
| Top |
Post subject: Re: stripped Freedom 15 as a SOT? Posted: Sun Apr 15, 2012 2:20 pm |
| Site Admin |
Joined: Fri Jun 18, 2004 8:14 pm Posts: 4643 Location: Greensboro, NC
If a 325 max payload and 27.5" beam by 15'6 long is acceptable, I could send you plans for a strip Wadefish SOT tomorrow. It's one of my drawing board projects that the prototype builder didn't get started on.
If you need bigger, then it's a custom project.
_________________ -Matt. Designer.
| Top |
JGood
Post subject: Re: stripped Freedom 15 as a SOT? Posted: Sun Apr 15, 2012 9:55 pm |
Hey Matt Do you have any preview drawings of the stripped Wadefish that you could post? Like the ones you post for your other designs. I would like to compare the Wadefish with the Freedom as far as bottom shape is concerned. I like the smooth flowing lines of the Freedom. I think it would be a very quiet hull with minimum slap noises from waves. Sneeking up on tailing Redfish requires stealth in shallow water. Both boats are about the same size dimensionally.
| Top |
Post subject: Re: stripped Freedom 15 as a SOT? Posted: Mon Apr 16, 2012 6:29 am |
| Site Admin |
I'll post them later this evening.
| Top |
Post subject: Re: stripped Freedom 15 as a SOT? Posted: Tue Apr 17, 2012 6:39 am |
| Site Admin |
| Top |
Post subject: Re: stripped Freedom 15 as a SOT? Posted: Tue Apr 17, 2012 7:58 am |
| Site Admin |
The name of the game with SOTs is matching the displacement of the hull at a given depth with the subfloor height.
The original customer wanted a narrow touring kayak. Problem with that is a narrow hull is less stable by nature. Make it a SOT with the paddlers entire body being raise 3-4 inches, it becomes even less stable.
So to get max displacement without it being completely flat, I used flat panel sections with rounded chines. There is also constantl flare going up the hull until about 1/2 the height.
It should feel stable to an experienced paddler with moderate balancing ability.
| Top |
JGood
Post subject: Re: stripped Freedom 15 as a SOT? Posted: Tue Apr 17, 2012 10:12 pm |
I have not built a stripped boat, yet. Do you think the small radius of those chines will be difficult to get strips to conform? I think narrower than normal strips thru the chines would be easier. What is the price for these plans? I may try it for the challenge. I would rather it had been the wider Wadefish stripped. Thanks for posting these drawings. Jesse
| Top |
Post subject: Re: stripped Freedom 15 as a SOT? Posted: Wed Apr 18, 2012 6:25 am |
| Site Admin |
The tighter curves will be a little harder to strip out. But as you said, narrower strips in that area would be better.
That's the only strip SOT I currently have complete. The go wider, I'd have to start from scratch.
| Top |
woodman
Post subject: Re: stripped Freedom 15 as a SOT? Posted: Wed Apr 18, 2012 7:24 am |
Joined: Wed Nov 03, 2010 7:12 am Posts: 118 Location: KC.MO.
You could always assemble the wadefish with stripped pannels...
| Top |
Page 1 of 1
[ 9 posts ] |
Who is online |
Users browsing this forum: Google [Bot] and 2 guests |
