Different types of epoxy question
jdzz
Type of boat I like: Sabalo
Post by jdzz » Wed Nov 14, 2012 11:21 am
I will able to get couple gallon of epoxy/hardener that use to create fiberglass oil pipes that to be use on the ocean floor for cheap.
It has 4-1 ratio and has to heat to around 155F before mixing.
Will I run into any problem using this epoxy for my kayak? If I am going to do a test on a small piece of ply-board, what should I look for?
Thanks,
jdzz
Re: Different types of epoxy question
Post by jem » Wed Nov 14, 2012 6:07 pm
I wouldn't use it. It will smell bad and how are you going to maintain 155 degrees?
PiratePete
Post by PiratePete » Thu Nov 15, 2012 4:28 am
jem wrote:I wouldn't use it. It will smell bad and how are you going to maintain 155 degrees?
& work with it without burning your self?
john the pom
Post by john the pom » Thu Nov 15, 2012 5:43 am
Run a hot bath and work underwater. Just like building ships in bottles only wetter.
Post by Oldsparkey » Thu Nov 15, 2012 9:32 am
jdzz wrote:I will able to get couple gallon of epoxy/hardener that use to create fiberglass oil pipes that to be use on the ocean floor for cheap.
Thanks,
jdzz
It sounds like you would be working with a nightmare of epoxy. The cheep stuff would cost you a boat before you are done.
It's better to use some epoxy made for wood boats and spend a little more then you will have a boat you could use and not just a pile of scrap wood that can sit on the ocean floor.
Post by jem » Thu Nov 15, 2012 11:06 am
jdzz wrote:
... has to heat to around 155F before mixing.
I'm a little puzzled by that. Did you mean it won't cure until hitting 155f?
In either case, like Chuck said, it doesn't sound like it will be builder friendly. It would be worth getting something from RAKA.com or uscomposites.com
jdzz
Post by jdzz » Thu Nov 15, 2012 11:37 am
Sorry for the confusion. Basically, the instruction to mix the epoxy and the hardener is to bring both up to 155 degrees Fahrenheit before mixing the two together. For simplicity, I think I will go with Raka or uscomposites.com
Thanks,
Jdzz
jdzz
Post by jdzz » Thu Nov 15, 2012 11:40 am
In case you wonder what those epoxy are using for: :D
http://www.aquaeitaliana.it/wp-content/ ... _fpi_1.jpg
Post by jem » Thu Nov 15, 2012 8:58 pm
wow! I bet it's special formulated for that application.
