The Stitch and Glue Tutorial states to maintain a gap between the panels. Should the frame also have a gap between it and the hull on the Sabalo?
After reviewing the plans, I found two dimensions that are missing: the location of the forward end of the CP Footwell Floor and the forward end of the TW Floor. How long are the panels?
Sabalo Construction
Sabalo Construction
David
David
Yes, maintain a gap between panels and frames that remain in the hull. Gap not needed for temp frames. For easy gap spacing, check out the "Tips and Tricks" section of this forum.
Review step #10 of the instructions. The frames for the cockpit and tankwell align with the reference lines drawn in step #2.
Hope that helps!
Hope that helps!
Thanks, you answered the question about the gap; however, I still do not understand how to cut the TW Floor and the CP Footwell Floor.
Sheet 4.4 does not show the distance between the forward end of the TW Floor and a reference line.
Also, sheet 4.1 does not show the horizontal distance of the forward end of the CP Footwell Floor and a reference line.
David
David
Boy you guys sure are picky. Next thing you know you'll want the boat to float too.CC TX wrote:Thanks, you answered the question about the gap; however, I still do not understand how to cut the TW Floor and the CP Footwell Floor.
Sorry about that. I'll e-mail a couple .pdfs
