Hey, i started building the free canoe plans, i have the first sheet all cut out. i just had a few questions. there appear to be gunwales in the picture, b ut i dont see them listed anywhere or layed out. And i also dont see the "frame Top" parts put anywhere on the canoe. I'm not farmilar with the term frame top, I assumed it was like the frame, but there are also parts for frames.
Another thing is the floor panels. HOw do i join them, just with a futty pillet? and what is floor center panel for? and im not sure, but the bulk head and deck lid should come together to form a closed front and back, correct? all the joints between wood, such as the joints between upper pannels a and b should be done with wood flour and epoxy fillets right? then fiberglassed? Should i pre coat the wood with epoxy before i stich them all up together? any other tips would be appreciated, sorry for the long post.
started building canoe, need help
Re: started building canoe, need help
You'll have to make your own gunwales. 1x2 lumber works well for simple gunwales.buildingacanoe wrote:Hey, i started building the free canoe plans, i have the first sheet all cut out. i just had a few questions. there appear to be gunwales in the picture, b ut i dont see them listed anywhere or layed out.
They are laminated to the frames to form a thicker thwart. Look at the upper right photo is this picture:And i also dont see the "frame Top" parts put anywhere on the canoe. I'm not farmilar with the term frame top, I assumed it was like the frame, but there are also parts for frames.
See here: viewtopic.php?t=25Another thing is the floor panels. HOw do i join them, just with a futty pillet?
The floor panel is made of 3 pieces that must be spliced together.and what is floor center panel for?
you got it!and im not sure, but the bulk head and deck lid should come together to form a closed front and back, correct?
check the link I provided above. Also, read the rest of the tutorials. That will help you a bunch.all the joints between wood, such as the joints between upper pannels a and b should be done with wood flour and epoxy fillets right? then fiberglassed?
You can but it's optional.Should i pre coat the wood with epoxy before i stich them all up together? any other tips would be appreciated, sorry for the long post.
Send me an e-mail. I have a file that will be useful for you.
Thank you so much for the info. The pirogue plans will help A TON! thank you so much, i hate to be a bother, but i have one more quick question. are the gunwales glued right to the sides? also, does this design use a butt block, or a splicing like it said in the tutorial? thanks, sorry im being so annoying. Seeya later!
