dangermouse01 builds a Wadefish 2.0
pogue3one
Wow.
Post by pogue3one » Sat Sep 29, 2007 10:20 pm
I mean WOW! I bet you never chopped your frame ends off with a ceiling fan. Keep that thing away from the upper Texas coast, you'll make us look bad.
Beautiful build DM.
Wadefish (complete)
Paddlin4Reds
Post by Paddlin4Reds » Sun Sep 30, 2007 8:10 am
Mornin';
:shock: ....Real nice! Now I need to get back to finishing mine. But, it will never look that good. :oops:
surfman
Post by surfman » Mon Oct 01, 2007 9:05 am
Darn nice boat you have built there DM. Very nice.
Tight Lines, Steve
pogue3one
Scupper tubes
Post by pogue3one » Tue Oct 02, 2007 2:23 pm
DM, what are the scupper tubes made of and did you use epoxy to secure them?
Wadefish (complete)
dangermouse01
Re: Scupper tubes
Post by dangermouse01 » Tue Oct 02, 2007 6:12 pm
pogue3one wrote:what are the scupper tubes made of and did you use epoxy to secure them?
My scupper tubes are 1.50" OD X 1.25" ID fiberglass tube that I got from McMaster-Carr http://www.mcmaster.com/ part number 8535K72
Scottrunnr's Tandem Fishing SOT build page (Page 6) has a link to another place to get tubes.
Mine are epoxied in, I made some squares from scrap 4mm ply and drilled a 1.50 dia hole thru some and a larger hole thru the others. Then epoxied one of each together. Made up 4 glue ups total, 2 for each tube, 1 for the top, 1 for the bottom.
Trimmed and shaped the ones for the bottom on the belt sander. The larger hole is on the side with out the curve.
The using the cockpit and tankwell to locate the tube and keep them in place. I traced the out line of the tube at the hull and gooped some cabosil thicken epoxy inside the outline and set the tube into it, still using the CP and TW as guides.
After that cured, carefully remove the TW & CP, mixed up more cabosil/epoxy and gooped it at the base of the tube, then slide the bottom plate down into it.
Then filled the ring on the top side with cab/epoxy, also poured some into the bottom of the tube to make sure any gaps were filled.
Top plate was about the same, the supports on the side of the tube are epoxied on first, then the plate sits on those
and the top is gooped with the cab/epoxy and the the CP or TW is brought down on top of it.
Then when it is time to cut the hole thru the hull, a 1.25" hole saw on an drill extender fits right inside the tube.
Oh yeah, every thing was given two coats of plain epoxy along the way.
Hope this helps.
DM
dangermouse01
Post by dangermouse01 » Sat Oct 06, 2007 8:42 am
Winds ENE 10-20, 40 percent chance of rain.
DM
14895
scottrunnr
Post by scottrunnr » Thu Oct 11, 2007 12:05 am
Wow!!!! What a masterpiece! She's really a work of art. I wish I could finish like that!
I like the additional support you placed on the fiberglass tubes for the scuppers.
Have you fished her yet?
FlaMike
Post by FlaMike » Thu Oct 11, 2007 1:07 pm
That's one scary-good job you did there! :D
Looking forward to seeing pics of her on the water.
Mike S.
Spring Hill, FL
dangermouse01
Post by dangermouse01 » Fri Oct 12, 2007 5:04 pm
FlaMike wrote:Looking forward to seeing pics of her on the water.
Mike;
Heres a picture of it close to the water, from last weekend at it's very first launching. :lol:
I do have some pictures of it on the water, being paddled by my girlfriend. The thing is, she is not wearing a PFD (it was in the boat, which is good enough for Florida law, I believe in wearing them) in the photos. And I am not going to post a photo of somebody paddling a boat and not wearing a PFD on Matt's site. So until I get it out on the water again and get some appropriate photos, this will have to do.
DM
Manjimike
Re: dangermouse01 builds a Wadefish 2.0
Post by Manjimike » Sat Oct 13, 2007 2:06 am
dangermouse01 wrote: Of course, for those of you following along here is my disclaimer:
1. I am neither a professional kayak builder nor a kayak designer.
This Wadefish 2.0 will be my third built, but my first JEM Watercraft designed kayak...DM
I don't think there are to many professionals that will match your skill :D
Cheers Mike
