TRR Laker build
TRR Laker build
Post by tx river rat »
Here we go again Started cutting out the  bottom panels and sides They are cut sanded and the bottom panels glued seemed like it was slow today for some reason.ImageImageMore tomorrowRon
FlaMike
Post by FlaMike »
And the Magic begins! :D
Mike S.
Spring Hill, FL
Post by Kayak Jack »
And it IS magic, isn't it. A stack of flat, flexible plywood begins to assume the graceful shape of an elegant watercraft. Magic indeed!
Besides playing with my granddaughter's I did get a little work done
cut out my stations
wired bottom together
stitched the sides and stations in
turned it over and started to stitch the outsides then got to thinking why can't I do the outside like I do a perow, think Ill try that instead of stitching the outside and bottom together.
Well dats all folks
for today, moma hollering supper is ready fried pork chops cream gravy
fresh okra and a big ole glass of sweet tea
Im gone before she throws it out
FlaMike
Post by FlaMike »
Ron,
I'm not quite sure what you mean by "like I do a perow." What is it that you are doing differently from the stitch & glue method? Are you getting a panel-to-panel contact and edge-gluing them together and then using fg tape?
Mike S.
Spring Hill, FL
you got it Mike
Using the poly glue and a filet inside works pretty good
FlaMike
Post by FlaMike »
Ah, now I remember! :D
You discussed the fact that you use the poly stuff instead of epoxy in a thread here, or on Old Sparkey's a while back.
Got it! :)
Mike S.
Spring Hill, FL
Got the bottom finished stitching and gluing . Started putting on the shear strips
got the fillets done on the inside
started installing bulk heads and filleting them
J h came by today brought me some 1/8 laun
so decks will be made of that
Little laker starting to shape up
Got the decks fit out fillet and glassed
turned the hull sanded it outImage
wet out with first coat
got the glass on the bottom
called it a day while that dries
Heya Ron,
You are a boat building machine mate. Beautiful clean lines too.
I reckon you will love this baot. :D
