SABALO BUILD
Bemm 52
Post by Bemm 52 »
Matt............the cutouts give me access inside the hull again :lol: :lol:
What are your thoughts on putting scuppers in the two back corners of the cockpit............I'm thinking 1/2" fiberglass tube I just happen to have lying around. :roll:
Do you or any of the guys have any thoughts? 8)
shouldn't be an issue. Scott does it on his SOTs.
scottrunnr
Post by scottrunnr »
Paul,
follow this link within the JEM site to see how I installed my fiberglass tube scuppers: http://jemwatercraft.com/forum/viewtopi ... c&start=60
Go about half-way down the page. I hope this helps (assuming you need any help :wink: ).
Bemm 52
Post by Bemm 52 »
Thanks Scott given me some ideas 8)
I thought I was nearly finished :oops: ........But I guess its not over until you are finished :shock:
PS really like your single you recently completed
Cheers Paul
Bemm 52
Post by Bemm 52 »
After being inspired By Olsnappa.s launch I pressed on this weekend
Scott decided against extra scuppers............ :(
as I .......just .....want .....to.....finish :) :shock: 8) :P
Handle Finished
Bemm 52
Post by Bemm 52 »
Got first coat of graphite on hull 8)
I have cut ply out and filled transducer shoot thru hole with thickened epoxy
Question will transducer shoot thru graphite?? :? :?
Scott I noticed on your Blue fin build you must have masked this area before you graphite coated :shock:
Is there a reason for this :o
Flump
Post by Flump »
G'day mate.....she's looking good. There's no worries about the transducer shooting through the graphite mix. I've got a Garmin 140 and thats fine through two layers of glass, ply and three coats of graphite epoxy :D
Build and paddle your own kayak - it doesn't get much better than that!
scottrunnr
That's amazing Flump that your fishfinder will shoot thru the ply. I was told by the manufacturer of my fishfinder (Eagle Cuda) not to shoot thru ply or graphite. Especially not ply. That's why I taped off the transducer cut-out area when applying graphite.
Bemm 52
Post by Bemm 52 »
Flump wrote:G'day mate.....she's looking good. There's no worries about the transducer shooting through the graphite mix. I've got a Garmin 140 and thats fine through two layers of glass, ply and three coats of graphite epoxy :D
Scottrunner quote
"That's amazing Flump that your fishfinder will shoot thru the ply. I was told by the manufacturer of my fishfinder (Eagle Cuda) not to shoot thru ply or graphite. Especially not ply. That's why I taped off the transducer cut-out area when applying graphite."
Two conflicting opinions.........maybe transducers work better in the southern Hemisphere?? :shock:
Flump and Scott thanks for answers.......I think I'll take cautious aproach and not graphite cut out... my sounder is pretty entry level so I dont know how powerfull it is :oops:
I thought I posted this before.
Will shoot through graphite - no problem. :D
