It is currently Wed Oct 18, 2017 10:39 am
 Post subject: Touching up the bottom
PostPosted: Sun Sep 27, 2009 9:13 pm
After a couple years and several hundred miles of being bounced off rocks pulled up concrete boat ramps landing on gravel bars the T-V needs a touch up on her bottom.
Examining the bottom most of the wear was on the first 2 inches of the bow and the last 2 inches of the stern
I did some sanding preping her for some more cloth and rosin.
After I get her back inshape I think I am going to put on some short wear strips.
More tomorrow.
 Post subject: Re: Touching up the bottom
PostPosted: Mon Sep 28, 2009 9:53 am
This is a Great Idea for all builds,Thanks :wink:
Mike
__Ralph Waldo Emerson
PostPosted: Tue Sep 29, 2009 7:03 pm
I accomplished a little more today on the T-V ,put on a layer of cloth ,let that dry then started fiting the wear strip for the bow.
Image after some sanding and shaping put on the first coat of cloth.
I made this strip a little longer and higher than first planned,I want to see what if any this does to the handling of the boat and all I have to do is sand it down thinner if I dont like it.
Mike I will let you know in a few days
PostPosted: Fri Oct 02, 2009 7:33 am
Ron, that looks like that will just wear out too, why didn't you go with something like a piece of that rubber keel guard stuff?
Tight Lines, Steve
PostPosted: Fri Oct 02, 2009 10:17 am
Steve
It will wear but is sealed from the rest of the hull so it can be replaced if I need too.
The 1/16 of cloth and glass lasted two years.
I figure this should last about ten,lol
Rubber might be alright but it will not slide and be hard to attach.
Now if I realy want to stop the wear I have some 3/16 abrasive rods I used to build up some drill parts,I could set one of those in the wood and never wear it out :D
PostPosted: Fri Oct 02, 2009 11:47 am
I thought I was tough on boats. :shock:
I do like that repair, looks like it could last a long time.
PostPosted: Fri Oct 02, 2009 12:03 pm
Got it, sort of like some nerf bars. :lol:
Tight Lines, Steve
Users browsing this forum: Bing [Bot] and 1 guest
