It is currently Wed Oct 18, 2017 9:03 am
Post new topic Reply to topic  [ 13 posts ]  Go to page Previous  1, 2
 Post subject: Re: Aperturestop's Okwata build
PostPosted: Fri Jul 01, 2011 10:59 am
Thanks everyone for your input. i see that it is probably just a matter of preference. I think ill just epoxy them in. I too am not taking this boat on anything other than lakes so I don't forsee any rough water or boulders.
My little girl got sick yesterday so purchasing of wood has been put off until this weekend.
I will follow suit with the other great build logs on here and post my progress.
Jeremiah
J.R. Coffey Photography
If it looks good, Shoot it.
PostPosted: Fri Jul 01, 2011 7:58 pm
I stand corrected then John. Might have something to do with the type of silicone you use. Some silicones may adhere to epoxy better than others. I did find that when I was building a perspex box once. I used one type that started coming loose pretty quick, but when I used another which was marine grade it held much better. Still, it wasn't anywhere near as strong as epoxy.
I intend to install one of the 'temp' bulkheads on my Sabalo permanently to create a separate storage cavity, and I will definitely be epoxying that one in. I will be using it as a support for a mast step, and need it to be as strong as possible.
PostPosted: Sat Jul 02, 2011 1:07 pm
I use the exterior stuff (made by GE and available at Home Depot) that is used around windows. I installed my bulkheads 5 years ago and there is no sign of deterioration. I used it on my Sabalo around the perimeter of all plastic hatches and rod holders. It's under the plastic and not exposed to UV. As I said before, I now prefer to epoxy the bulkheads. However, I thought I would at least recommend that particular brand of silicone if anyone else is looking for a brand that bonds well to plastic and epoxy for hatches and rod holders.
Users browsing this forum: Bing [Bot] and 2 guests
