It is currently Sun May 19, 2013 9:43 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: TV 15-29 strip build
PostPosted: Wed Aug 03, 2011 8:05 pm
The last panels in place and ready for glass...
PostPosted: Wed Aug 03, 2011 8:09 pm
Got the cloth on and letting it set for a day...the epoxy just arrived what timing...I have been making my own squeegees from plastic laminate with a strip of 1/4''ply screwed to each side...
PostPosted: Wed Aug 03, 2011 10:59 pm
Hull looks good in raw timber - should be great when glassed 8) .
Just a little concerned about that squeegee - it looks like there are sharp serrations around the edge - or is it just reflections? If they are serrated it might pay to check that they won't snag the cloth. If you start applying epoxy and find all your squeegees are catching on fibres then it could be a bit messy (and panicky too).
PostPosted: Thu Aug 04, 2011 8:10 am
No it is smooth this is the 4th boat I will have done using this type. I radius the corners...small strips of laminate can be sanded into whatever radius needed for doing fillets also...
PostPosted: Fri Aug 05, 2011 9:39 am
Well got the glass on this morning....The shiny spot down the keel is the left over oz. of epox. I just spread on instead of throwing out...Their is no strip color layout.. it's pretty ugly in that respect...and it took all of 1 beam to get the hull done....
PostPosted: Fri Aug 05, 2011 5:44 pm
Your going to like that boat
PostPosted: Sat Aug 06, 2011 7:17 am
I think so to Ron it reminds me of my first build.
My first boat the 14' tandem had a bottom panel that was 25'' wide and at the 4'' waterline it was 31'' wide I could stand up in that boat.
I know this one is not quite as wide but it will be stable when I raise the height of the seat to a comfortable position...
PostPosted: Sat Aug 06, 2011 10:59 am
My T-V has a seat height of 9 inches and is stable as heck.
PostPosted: Mon Aug 08, 2011 11:37 am
Got the outside glassed and a couple of fill coats on...Fliped it over and did fillets ...Then the fun began this morning glassing the inside of this was a bit of a time consuming challenge with those tumblehome panels 3 hrs. later done ....
PostPosted: Mon Aug 08, 2011 12:41 pm
The inside is never any fun. I usually lay the boat on its side, due one half, let it cure, then do the other half. A little extra sanding to taper the edge of the cloth so the other half lays over it clean, but not too bad.
Users browsing this forum: Google [Bot] and 2 guests
