New Stalker Build
Falcn
Type of boat I like: Solo open canoe
Re: New Stalker Build
Post by Falcn »
Photo update:
Building the new foredeck.
Strips of oak hot glued to a plywood base and then epoxy filled joints. The epoxy has graphite included which makes it black
To get a slight convex bow I set the oak strips on a form
The surface epoxy has now been sanded off leaving a nice little black pinstripe between the planks. You can also see I used a white wood for the centre plank.
The sanded foredeck
The main foredeck completed. I now need to put a raised back onto this and finish shaping it to fit the hull.
surfman
Post by surfman »
Very Slick!
Tight Lines, Steve
goanywhere
Post by goanywhere »
Wow! That's very nice. Will be spectacular when you're finished. :shock: :D
Very nice!
Manjimike
Post by Manjimike »
Falcn wrote:Maiden Voyage photo report ...
Are they UK canals you're paddling on?
I've walked quite a few in the Marple area.
Cheers
Mike
Falcn
Post by Falcn »
Yep, this is the Chesterfield Canal at Kiveton Park
(http://maps.google.com/maps?q=kiveton+p ... 0&t=h&z=19).
The closest bit of water I could find :lol:
Manjimike
Post by Manjimike »
I was just over the hill from you in May this year :D :D
Cheers
Mike
rodot
Post by rodot »
Ditto
Roger
Okwata LC,
Northwind,
Quetico
PiratePete
Post by PiratePete »
That is one sexy bit of deck
I can't wait to see it when it's finished & all polished up :D :D :D :D
Falcn
Post by Falcn »
The foredeck is now finished and being glued into the boat overnight. I should be able to epoxy seal the deck over the weekend.
The finished article
The rear upstand
All ready to be glued into the boat
