Thinking about it, I do get some bubbles in the epoxy when I use the roller.
The way I address it is to let the epoxy set up a bit, about 5 minutes or so. This short time ensures all the bubbles that are going to form, have formed but the epoxy is still in a liquid state and workable.
Then I hold a chip brush on about a 45-degree angle, and gently drag the bristle tips across the epoxy surface to pop the bubbles.
I only use enough contact force to barely bend the bristles and pop the bubbles. Since the epoxy is still in a liquid state, it self-levels out.
Only draw back to this process is if you use really cheap chip brushes, the bristles pull out and lay in the epoxy. So before I use this "tip-off" method, I'll drag the bristles back and forth across a clean rough surface to try and remove any loose bristles.
After I'm done, I'll clean off that brush with acetone or vinegar and safe if for that process again.
Foam Roller Bubbles
Teddy Madison
So from the results I am seeing, the only reasons to use a roller seem to be:
1. Get the epoxy down quickly.
2. Apply epoxy to a verticle surface.
3. Personal preference.
You still need to finish off with another method such as a chip or foam brush or squeege in most cases.
works for me, I just want to get a grip on it as I am probably one or two days away from glassing the hull.
Wayne
Wayne
Wayne
Free Laker - In Progress!!!
dangermouse01
I never use a roller for applying epoxy. It is always a squeegee (yellow plastic type) and a disposable chip brush, whether I am glassing the inside or outside of a hull. The squeegee for most of the work, even the vertical stuff. It puts down a thinner coat (dont have to worry about the cloth floating), lets you stretch out the cloth when wetting it out, easier to move epoxy around and doesn't absorb any epoxy. I use the chip brush for wetting out taped seams, edges and small areas the squeegee can get into.
Heres a tip for Lee on filling the weave:
After you put the cloth down (initial epoxy coat) and you have applied you first fill coat, let the epoxy cure. The lightly go over all the glassed area with a carbide scraper or a cabinet scraper (fine grade sand paper works also), you just want a light shaving off the top. Wipe the surface down and apply another fill coat (second fill coat). After that cures, scrape the surface again, clean and apply another fill coat (third fill coat). After that cures, scrape it again and by then the weave should be pretty well filled ( 1 wet out & 3 fill coats).
What happens is the weave of the cloth, one strand over then under then over......, when applying fill coats, you are building up the tops while you are trying to fill the lows. So if you knock the tops down a bit in between coats, you fill the lows with out building up the tops and save about two coats of epoxy. This is where using a squeegee pays off, thin coat on the tops and doesnt pull epoxy from the lows. Saves time & effort in final sanding too, and thats a good thing
DM
DM
LEE SCHNEIDERMANN
