What an exceptional boat. The attention to detail is amazing.
I can't wait to see the finished product.
Your pictures are getting me motivated
Sabalo 14
CC TX
Installed the remainder of the cockpit floor, glassed the seat, started the cockpit front wall, made rudder support side brackets, and started the storage area behind the seat. http://www.picturetrail.com/tx-kayak
David
David
Hi David,
Nice job mate. Are you going to feather the blades on your paddle and are you going to laminate the shaft?
If so, How do you plan to ensure a uniform thickness of the shaft and how are you going to attach the blades please.
CC TX
Hi Mick,
Yes, I plan to feather the blades. The tang that you see on the blades will go inside of the shaft. I will then add a little more plywood for reinforcement and to fair out the joint. As far as the rest of your questions, I am still working on different alternatives.
One idea for the shaft that I am thinking of is to make a hollow hexagon of plywood strips and then cover with a glass sleeve.
Another option that I may try is to laminate glass and graphite. I will need to find a thin, lightweight core to mold this over. I have thought about using a shatter shield that they put over fluorescent bulbs. It is a little larger diameter than I want; however, I may be able to slit it and shrink it down. I am still looking for other core materials. I have also seen a shaft made this way with a removable core such as pipe or metal tubing. However, I am afraid that if I do this, my pipe may be stuck inside of the shaft that I am making.
I am also considering another alternative for the blade: Laminate two pieces of 3 mm plywood in a curved form.
With the Hobie drive, I will rarely use a paddle. However, for safety sake, I will always take a paddle with me. Ha! If the Hobie drive ever fails me, it could be a long, long paddle back.
To all, Thank you for all of the compliments!
David
David
cellmate
