Canoe Outriggers
Re: Canoe Outriggers
It's almost a case of picking one of your designs, setting the outrigger to suit that but letting everyone know that it will fit one perfectly but has to have modified poles for anything else.
Whirly
- Type of boat I like: 18-36 Trapper
G’Day Matt,
As most boats are going to have different heights of freeboard and locations for mounting the beams, how about something adjustable that will suit all? If built out of timber, then it would be a just matter of suppling the curves required to laminate the beam for that particular craft. With aluminium though something needs to be adjustable, and can be fixed in place once the correct placements have been set-up. Was thinking that square or rectangular section would lend itself better to this, than round.
How about along these lines?
The wedges could be made from hardwood, ply laminates or perhaps nylon blocks. This could be set up for one or two outriggers and the centre pieces can be drilled or have eye-bolts to assist with lashing onto gunwales or thwarts.
With everything bolt-together it should be good for transporting.
Anyhow, just some ideas…….
Cheers,
Whirly
Cheers,
Whirly
ralphobarly
- Type of boat I like: Trapper designs
Matt,
I'd be looking for more of a traditional single outrigger vs a catamaran design with one on each side. Would I be able to use the same design and just use one?
Thanks again
Matthew
Thanks again
Matthew
Tor
I like the Whirly solution to the beams which the wedge could be made of rubber and the brackets designed to allow some movement so that the mounting is "soft".
The great thing with straight beams is they can be stored and transported easily, this seems to manage this and give a generic float.
Almost like an oar set up but finding a way to lock the oar into a various fixed positions.
goanywhere
This is how I mounted my outriggers to my yak. It is possible to mount the T piece the other way to make the mounting adjustable in height on the outrigger end. The advantage of this is that it is possible to adjust the height of the outrigger for different conditions or onboard loads. Something along the lines of this design would make the use of a straight aluminium bar acceptable for most kayaks and canoes for either a single or twin beam rig.
RobRassy
- Type of boat I like: canoe and sailing dinghy
Hey Guys
Just finished an outrigger of sorts for my trapper project
I'm calling it a stabaliser because it's not really an outrigger and not designed to be used while under way
The concept is to keep the craft streamlined till you get to your fishing spot then deploy the stabiliser
It was actually designed to allow crab pots to be lifted, but will also create a comfortable fishing platform
What I have done is build & modify a spare (emergancy when touring) paddle so it can be attached to the centre thwart, and mounted a float on the end of it
The whole thing is held in place with 2 bungy straps, is on board when travelling and can be deployed in seconds
An appendage on the paddle shaft hooks under the inwhale and the handle end is strapped to a block mounted on the thwart
One of the main considerations in the design is limit the float bouancy so that it will sink before doing damage to the canoe or paddle
For that reason the canoe should still be able to be capsized, although early testing has proven it to be very stable
It's a pretty wild idea and takes a bit of explaining, so I'm hoping some pics will do it
This is the paddle - 60" long 24" blade
This is the bit that hooks under the inwhale
The mount on the thwart
A bungy Strap holds it in position
The float slips on the end of the tappered blade and is held in place by a bungy cord
This is what you end up with
I can safely sit on the guwhale and lean out
With some extra weight in the front - even more stable
This is simulating those crab pots - 10kg at arms length and leaning out as far as I was game
Another design goal was to have the stability increase gradually so you still get the tippy feeling, and don't forget your in a canoe
This has been achived with the shape of the shape of the float having most of the bouyancy high and close to the paddle blade
It hasn't been tested in the real world so I hope it's not a WOFTAM
Will let you know in any case
Cheers
Rob
Cheers
Rob
Innovative! What's that float made of? Looks almost like a chair cushion.
RobRassy
It,s glass over foam
Blocks of foam were glued together with a gap for the paddle blade
The blade was then pressed into a bed of Q-cells with a layer of glass on top
Then the top of the blade was coverd with glass, Q-cell and a foam fill in block
I shaped and tested the float before removing it from the paddle, and glassing it
Rob
Rob
