you got that right...build it as you need it!
Sounds like what you want to do is "cold molding".
You could also build with one layer of fiberglass, and then on the outside bottom put a layer of Dynel cloth. Dynel cloth is more resin thirsty but very tough. It won't add much stiffness by along with the graphite, I think you'll get more the abbrassion resistence than another layer of plywood.
Jcubero's Merrimac
surfman
Well the extra layer of ply was not for abration resistance but more for stiffness. Instead of applying ribs. to prevent oil canning. I am not so sure I want a bottom that will flex a lot. Is it okay to just go ahead and thin epoxy with acetone or is that more of a question for the epoxy manufacturer?
Other thoughts - notice how easy it is to come up with a lot if wild ideas if someone else has to spend their time and money to do them??!!)
Some strips of 1/8" plywood of, say, 3" width running longitudinally would stiffen it a lot. Glue these to the existing bottom.
I'd want a platform or low-sided box for a battery. Also, consider sprinkling some baking soda around in that box and laying a rag or old towel in there under that battery. Battery acid and wooden boats may not be a good mix.
HINT: use REAl baking soda; gree-itz won't work.
What Jack is thinking about is the same thing I did to the bottom of the Swamp Girl to stop the oil canning since I used such thin wood to build her.Kayak Jack wrote:
I used 3/4 inch strips....... since that was some left over wood from making her.
A closer look........
The center was built up to stop the problem and help to save on the weight.
