Tassie Wadefish
Re: Tassie Wadefish
The thinner ones would work. Not sure how to describe than other than smaller than standard. Maybe 6" long?
Re: Tassie Wadefish
I used these on my Laker:
The pros and cons of each method have been discussed before and ultimately it's a matter of what suits you.
Anyhow, it looks like things are coming together well, keep up the good work
Bemm 52
Re: Tassie Wadefish
Wow watching this build with a lot of interest.PiratePete wrote: so I can keep the off cuts of ply for the Mirage Drive Socket.
PiratePete
Re: Tassie Wadefish
Thanks Onkabob
I am a sparkie & use that size a lot at work but find I break a lot if I pull them up tight & was worried that they would be too weak for the job & the next size up would mean too big a hole.
I might get a few packs for the daughters for when she helps with hers.
PiratePete
Re: Tassie Wadefish
Thanks Bemm I read the spots off your posts.Bemm 52 wrote:Wow watching this build with a lot of interest.PiratePete wrote: so I can keep the off cuts of ply for the Mirage Drive Socket.
Re: Tassie Wadefish
Depends a bit on the amount of twist / bend in the panels and also on the spacing. You might need a couple of extra holes at the ends and some temporary support while you get enough ties in place.PiratePete wrote: I break a lot if I pull them up tight & was worried that they would be too weak for the job
If you find the twist is too much and have to stick with wire then you might try Tor's trick of putting the ends on the inside of the hull. It's on page 2 of his Southwind build and is a very elegant solution to the punctured finger problem (viewtopic.php?f=8&t=2535&st=0&sk=t&sd=a&start=10).
PiratePete
Re: Tassie Wadefish
Yes I have already decided that would be best for Cate's boat if I dont go with the wire ties
PiratePete
Re: Tassie Wadefish
I got some more done on stitching up the Wadefish tonight but I seem to have a hump just to the aft side of the joint at the centre line. Some how I have a slight bow in the joint of the port side bottom panel & this is distorting the bottom.
I can push it out with my hand but it pops back up again when I let go. Should I tie that panel down to the side rails of the seat support???
Re: Tassie Wadefish
That happens on occasion to some builders. To address it, I've seen the use of a little bit wider spacers in the area of the dip and it brings it right out.
PiratePete
Re: Tassie Wadefish
Thanks for the tip on the spacers Matt it worked a treat.
I used the jig to set up the bow tonight What a magic idea.
I love twisting ply into such a beautiful shape. Hopefully I can get the stern done tomorrow & Im ready to glue it together
