Not much to report other than I for some D.A. reason
, decided I was going to use “poor man’s” peel ply on the inside tape joints, to keep the sanding down…
Well, first off the areas are not finish level areas, plus I have a layer of biax to add and the taping of the bulkheads and stringers to go…Well I did the peel ply thing and ended up with a lot of epoxy ridges, wrinkles and boogers to sand on the starboard side…. The port side went on normally, no peel ply very little sanding…. So, how much sanding did I save on the starboard side
…. well, five 80 grit belt sander belts and 20 some odd 60 grit 5” disks later, I’m almost done fixing the starboard side…
I actually got in the boat to aid my back in the sanding…It’s gonna be a sweet creek boat, a lot of room…the boat building juices are flowing again
I have decided to scrap the plywood bulkheads and use Divincell for the bulkheads and stringers and Nida Core for the decks…It will cost me a little more (okay alot
), but the weight savings (more tackle) will be worth it…I hope
I hope to finish cleaning up the epoxy mistakes this week and get ready to lay the biax fabric next week…If anyone has 10 yds of 50” 1200 laying around drop me a line
To Be Continued...
