SSSSAAAWWEEEEETT!
Man, I hope my wife don't see this post, I would instantly be building another boat . . . for her.
Touring T-V (SS) Electric
- Type of boat I like: All boats
Re: Touring T-V (SS) Electric
I have done a little more on this boat. It seems like I work on it everyday but have little to show for it. I finally have it figured out, I think. I have the livewell and seat base glued in. I used a 1 1/4" aluminum tube for a drain from the front to the back. The other aluminum tubes are for the steering lines and electrical cables.
I fitted the livewell hatch and floor for the area where the batteries will be.
This boat is really starting to come together like I wanted. I really think the second boat will go quickly. I spend more time thinking and planning how I want things than actually building. I am still debating where to put the depthfinder transducer. I think I will put it under the seat instead of on the transom. I have never liked having a transducer on the back of the boat. But, on the other hand, I don't like the idea of cutting a hole in the bottom either. Even filled with epoxy and covered with cloth, I still think it will be a weak spot in the hull, and sooner or later, that spot will hit a stump. Still thinking about it.
Terry
Good grief...
very nice!
I cut a hole in my Sabalo hull filled it with thickened epoxy then glassed over it when I glassed outside of the hull........ also glassed the insidetw541 wrote: I think I will put it under the seat instead of on the transom. I have never liked having a transducer on the back of the boat. But, on the other hand, I don't like the idea of cutting a hole in the bottom either. Even filled with epoxy and covered with cloth, I still think it will be a weak spot in the hull, and sooner or later, that spot will hit a stump. Still thinking about it.
The boat has a pretty rough and tumble life and Ive had no problems with the cutout
Nice build by the way
was this made from a set of custom plans from JEM ?
If done properly, (as I can see you'll do), I wouldn't hesitate cutting in your transducer. Would you please post the finished weight?
I hope to get back to work on these boats soon.
Yes, these are from a custom set of plans from Matt. It is based on the TV, but is quite a bit wider. When I get closer to being finished, I will weigh one of them and post the weight. It will be pretty heavy for a 12'6'' boat, but I have planned from the beginning to trailer them. I put in a lot of reinforcing to support the weight of two deep cycle batteries when on the trailer.
Terry
I think I'm going to go with your plan but keep it a little lighter. I'm going to use one battery and a 30lb thrust trolling motor.Ideally I want to transport in the bed of my truck.
again great job !!
again great job !!
