I cut a pattern for each panel needed. I cut them from osb board this time. I used cheap 1/4 inch plywood for the patterns on the Sasquatch, but I think the osb will work better. It's also cheaper. I trimmed my patterns to exact size on the router table. I them laid them out on the table, and set them to exactly match the QA measurements in the plans.
I drew the outline on the paper on the table, covered with wax paper and assembled the panels to the lines. I did not want more holes than necessary to fill, so I tried something new this time. I used my 23 gauge pin nailer to fasten the strips in place. These little pins leave a very small hole that is almost invisible when finished. The small plywood strips help hold them down.
After the glue dried, I pulled the blocks straight up off the pins. These pins are headless, so the blocks pull off easily. I then pulled the pins with pliers. I think it is going to work very well.
Now it's just a matter of gluing up the rest of the panels.
