Finally gettin' started on my WadeFish 15 (Drawing Pack Revision 00- 05/04/06). I was runnin' over some of the drawings prior to actually drawing on my plywood. I seem to be missing something, or there is some missin' dimensions. My "Nesting" drawing depicts Sheet 4, as having the "Aft Cockpit Wall" with a small rectangular tab on the bottom. Then sheet 4.1 Shows the dimensions of the Aft Cockpit wall, but I don't seem to have enuff info to determine the Height of the wall or any dimension for the tab on the bottom depicted in the "Nesting" drawing( I show a dimension from the bottom of the sheet, the walls bottom width, the top edge width, and an overall top edge width ....with a 1/16" of "slop factor"). I must be missing something.
Wadefish 15 Question
paddling4sharks
Mornin';
Also, this "small tab", doesn't seem to appear at all on the "Cockpit Assembly", Step 12, pg. 18-20 of 45.
paddling4sharks
paddling4sharks
Mornin' Matt;
Did you receive my E-mail? I sent it to info@jemwatercraft.com. Hadn't received a response.
Thanks
Thanks
paddling4sharks
