We tried a different approach to make the hull easier to build and lighter.
Instead of needing to build a complete deck top, the builder well install a subfloor. This allows for more open interior room.
It will be easier to build. Some simple frames are installed to the mid hull area like other JEM SOTS. Then, some 1/4" cleats are glued to the hull side. The top tumble home hull panel is installed after the subfloor is installed.
Please note: the attached is just a simple sketch.
Mick,
below is a VERY rough drawing I made of the seating I had in mind. I know that Matt will do MUCH better justice to it than I did. I think Matt also wanted to shift the whole "cockpit" back 6".
Here are photos of the panels. Please let me know if you want more specific photos. For the most part they look fine. However, I haven't aligned them and checked the measurements yet.
1. Panels 1A/C
2. Panel 1A
4. Panel 1C
5. Panel 1B
6. Panels 2AC-4AC
Matt,
I received the templates for the frame slots this afternoon.
I have panels 1-3 spliced/glassed together. I'll save doing panel 4 until I need it. I'll cut the frame slots today, cut the semi-circles in the cockpit frame, and start splicing the cockpit frame tonight. I should be able to start stitching the panels on Friday.
Should I fit the lateral frames to the cockpit support when assembling the hull? That's how it's been done in the past. Your drawings for the new build show the lateral farmes w/o the cockpit support.
