Cutting and layout could not be more simple. In fact, with my back aching after drawing all the lines, I called in a helper to handle the utility knife.
This foam can be a little ornery at times though. For no apparent reason, it might ball up or tear out during a cut. The best thing you can do is stop immediately and cut from the other direction. Go slow and make several light passes. Most of our cuts were very clean. One tip I discovered is that applying a little pressure with a ball point pen while marking the layout lines helps tremendously. It puts a slight groove in the foam that the utility knife tends to follow.
Here you can see the method I used on the curves. It was nice to be able to just push in some finish nails by hand and then clamp my batten to them.
First panel is done and I've cut out all the parts. My back is sore and I'm not setting any artificial deadlines on this one. Just taking my time and trying to avoid mistakes. I'll be glassing the interior side of the panels before assembly with 6oz. Then I plan to run biaxial tape on the fillets. I'm on track to glass up the first panels this weekend but I'm taking my kid fishing first!
